lifting with Auto Ride
01Konvict
Boats n Hoes
Raleigh/SML
Yes I've pulled several springs out the Denali and escalades. You can tell by counting the coil turns. The higher number are the z71 springs. Reason why z71/Denali/esky all have higher tow ratings.
Snyder24
You think a set of new ones will bring it up any? If not I can always get back in the computer to see if I can try to recalibrate it to set itself higher upon ignition.
01Konvict
Boats n Hoes
Raleigh/SML
It's possible but did your air compressor kick on almost every time you started the truck? I think your rear ride height sensors are off. Fix the sensor angle to stock and lift from air shock will occur.
Snyder24
Air compressor comes on each time it fires up, for about 6 to 8 seconds. If the sensors are off, is there a descriptive and easy way to adjust them at each unit? Or does this need to be done through the computer?
Snyder24
That all makes sense, do you have a picture of the rear extensions installed? I guess it's as simple of getting them on, extending them slightly each side to make sure they even, they adjusting them again the same amount for the lift?
01Konvict
Boats n Hoes
Raleigh/SML
You got the idea! Just make them even or very close. The system doesn't need them perfect. You can adjust them as needed. Yeah I'm slacking on the pics. Will get some this weekend.
01Konvict
Boats n Hoes
Raleigh/SML
No link only available if you call them directly over the phone, number is listed on their website.
AceDawg
