Doug118
- Joined
- Sep 22, 2012
- Posts
- 545
- Reaction score
- 1,012
The back is starting to ride like total crap. Something bottoms out hard over dips. Not sure if it's the shock bottoming out or the rear end hitting the frame but it's starting to get frustrating. I'm ready to put the stock suspension back in the truck because I don't feel like having to buy $500 adjustable shocks
Yes the crossmember has plenty of clearance for the panhard bar mount. The front rides beautiful but over big off camber dips, the tires rub the fender in the back and I’m only on a 255/50/20
My back does the exact same thing you described but also bottoms out. I was just thinking about the tbss bags but I’m probably just going to order a 4” drop spring for the rear and either ditch the drop spindle up front or put stock shocks back in
As mentioned, I am going to ditch the Belltech drop struts and go with the Ranchos bolted to the bottom of the control arm with Grade 9 hardware. With the 2"spindles and without the 1/4" spacer I am guessing it will be 3.5-4" up front.
I have always thought about mounting my front struts under the control arms but it looks like one hard bump where your strut bottoms out, your strut bolts will break and your front end will be on the ground. why cant they just make shorter struts?
