Jason in DLH
Cheeseburger and Fries
Thanks to @89Suburban for recommending my oil leak to be a Valley Pan Gasket leak. I’ve looked further into it and it certainly is a problem with the NNBS it seems and will be replacing mine.
With that said...I’m looking for advice in other preventative maintenance items to change while I’m in there. So far, I’ll be replacing these:
-Valley Pan Gasket, and Seals
-Intake Manifold Gaskets
I’ll also clean the throttle body while it’s out and will clean the oil pressure sensor filter since it’s easy access.
Anything else I should change/clean?
2007 Yukon Denali 6.2L L92 with 140,000 miles.
