Ok I guess the 6.2 doesn't have the solenoids on it? In that case why buy a new cover and just by the gaskets for 1/3 of the price??
Thanks for the info. I’m interested to see the amount of oil in the manifold.
I’ll take your advice and swap out the driver valve cover (once I find it).
Definitely will be installing a catch can in the near future as well.
I’ve always used CRC Brakleen...is this “skim milk” to the Super Tech?
Performed TSB 10-06-01-008M that included: changing the driver side valve cover w/# 12570427, installing deflector# 12639759 on the oil pressure relief valve, flushing/soaking all cylinders/combustion chambers w/Motor Medic solvent
Whatever is in the manifold is just what hasn't yet made it into the cylinders.
I don't know if they still have it as an option, but I thought CRC completely went away from chlorinated brake cleaner. Maybe they've changed the formula since then, but I recall it being really weak. I didn't like the idea of paying twice as much for something half as strong. In addition to quickly cleaning, I use it for starting bonfires. So I need the flammable stuff. You just have to be extra careful when using the Super Tech, or any chlorinated cleaner for that matter. But, I'm sure you wear proper PPE when using any chemicals, riiiiiight?![]()
Oh brother...sometimes I just do dumb things!![]()
That's kinda why I was asking, but some people just like shiny new parts, even if they'll not be seen. If that new one works for you, you can easily sell your original one to someone here piecing together an AFM delete kit. There's always a "pay it forward", right?![]()
The Last time that I bought some CRC at Walmart, they had the original red can spray and the newer green can spray. I definitely recommend the original red can.Yeah...now that you mention it the CRC is different. Didn’t look to close at it the last time I bought it. I’ll try the Super Tech stuff. I really should use my mask with that crap. At least I open the garage door.Thanks for the info!
Jason I am noticing that cover you picked does not have the solenoid assembly on it. Please be aware they are riveted on at least in my case. Don't want to see you tear it apart for nothing and be screwed like I was. Not sure about the 6.2's never messed with one.
