Looking for Z-71 interior trim
StevenFromTexas
Mr. Negative
Lubbock, TX
I ordered three more replacement parts for the fake wood trim on 07-20-11 -- parts 25807745, 25909747, and 25909753. I'll post an update on those three items after I receive them in about two weeks.
If everything checks out with the above order, I'll order what I believe are the final three parts -- 25807743, 20877680, and 20883864 -- to complete the eight-piece switchover from the fake wood trim to the Z71 trim on a 2010 Tahoe LTZ, and then post an update on those three items also.
Millsp
Virginia
Z71 interior is the way to go with the brushed aluminum and the speacial leather seat trim.
Rhykor
2011 Tahoe LT Driver's side brushed aluminum power window part number
Hi everyone!
So I have seen lots of part numbers for the pesky driver' side window bezel/cover in brushed aluminum for the Hoe. Does anyone have the exact part number that also has the openning in it for the power mirrors on a 2010/2011 model?
My local GM dealer just laughed at me and said good luck when I went in there trying to get all of the part numbers and I think I have everything EXCEPT for the darn drivers side door. I should probably double check the passenger side also but any help would be GREATLY appreciated.
StevenFromTexas
Mr. Negative
Lubbock, TX
Hi everyone!
I think the numbers I have provided in my posts are going to be the correct ones for the Z71 parts. I've already replaced two of the eight parts as described in an earlier post. I've got three more parts coming in soon. And in about two weeks, I'm going to order the last three parts that I think I need. I'm putting my money down on part 20877680 (which apparently has changed to part 20980433) for the driver side front door switch bezel.
Tell us what part you think the driver side front door switch bezel is, Rhykor.
Rhykor
Door Part Number
I have part number: 25801742 and when I look up the parts description it indicates that it has the openning for the heated power folding mirrors so I am thinking that this is the correct part?
So far for my 2011 Tahoe Project I have the following parts numbers:
25909753 (Pass rear window)
25909747 (Driver rear window)
25909716 (Pass front window)
25801742 (Driver front window)
25807743 (Driver side instrument panel)
25807742 (Passenger side instrument panel)
25807745 (Center Console)
25807746 (Center Console Instrument Trim)
20951471 (Floor Console Insert/Trim - I had not even thought of this until I saw your pics)
Does this look right for a 2011 Tahoe LT? Again, my local GM dealer has not been very helpful with these parts. Everything else has been great, but not this endeavor.
StevenFromTexas
Mr. Negative
Lubbock, TX
Here are the three items I don't necessarily agree with you on:
1. 25909716 (Pass front window) -- fireman297, who started this topic, and I both think the part number is 20883864. I don't think 25909716 is a part for 2010/2011 models.
2. 25801742 (Driver front window) -- I think the part number is 20877680 (which apparently has changed to 20980433). fireman297 thinks it's part number 20877677. I don't think 25801742 is a part for 2010/2011 models.
3. 25807742 (Passenger side instrument panel) -- The part number is correct. I don't think this part is needed on an LTZ. However, it may be needed on an LT.
StevenFromTexas
Mr. Negative
Lubbock, TX
Confirmation that parts 25807745, 25909747, and 25909753 are the correct replacement parts for those that want to go with the Z71 look over the fake wood look. Installed this evening. :)
Five parts ordered and installed; three more parts to order to finish the project! I'm certain on part 25807743, but I'm going to do a little more checking on parts 20877680 and 20883864 before placing my final order to complete the eight-piece switchover from the fake wood trim to the Z71 trim on a 2010 Tahoe LTZ. I'll post another update at a later time.
StevenFromTexas
Mr. Negative
Lubbock, TX
O.K., I just ordered parts 25807743, 20877680, and 20883864. Further information to follow after I receive the items.
Wakinvol
East TN
what was the grand total for all the replacement pieces. I want to do it too, but It looks like it could be costly!
audley71
