Looking to purchase autoride front strut for 2010 Denali
t.stimpson
I honestly have no idea. But I have noticed when looking through the options that the 22" wheel option is only listed on the rear shocks, not on the fronts. Not sure why but thats what I noticed. If you go to rockauto.com and look up your vehicle. It will list the front and rear shock absorbers with a suspension code listed next to the different parts. I would suggest you look and see if any of those codes are listed on your sticker in your glove box. That sticker tells you which suspension system you have. Mine was Z55. This explains it better. http://www.shockwarehouse.com/news/gm-suv-suspension-decoder.cfm. So if your sticker says Z55 then I would think it would be the same regardless of wheel size in the front, it might be only the rear shocks that are differnt. But again, I'm no expert. this is just what I have found out.
ndavis0001
ndavis0001
Davis Motorsports
Jacksonville, FL
Yea mine is sorta rare I guess it's a Yukon Denali hybrid came with 22 factory I have 26's on now.
I will look at the Rock auto link when I get home.
Thank you!
ndavis0001
ndavis0001
Davis Motorsports
Jacksonville, FL
right. the ac delco auto ride shocks on amazon are the same as factory. But you do have to figure out part numbers so get the correct one. these are the ones I purchased for my 2009 denali. http://www.amazon.com/gp/product/B00EDQ2EM4?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s02
Ok ordered it should be here by the 9th... My guy is charging me 100 because he has to remove the hybrid unit under the hood to get to the bolts and connector... Sucks! Then I need an alignment on top of that so that'll be a 200 bill
The_Bob
