i am guessing this is in the right thread. I am having the dreaded loose steering wheel issue. The pitman arm looks good, i dont have much play in the wheels. I filled the PS pump up with fluid. Im not too familiar with the gear box since my other car as the rack and pinion setup. The Gear box does seem a bit old, i dont want to toss another one in if that is not the case. Is there anything i am overlooking that could cause this? Sensors or anything? It is a 96 tahoe 2wd LS
Thanks you
Thanks you
