Losing Hvac fan speeds.
OR VietVet
Multnomah Falls
Military
Willamette Valley
You might want to update your signature and put Silverado in with the 2001 Z71, because we don't know if is a Silverado or a Tahoe, unless of course you think that ALL parts are the same for each.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Vin 11126218
BY VIN# came up with
GM#22807122 $72.82
FOR THE MATEING CONNECTOR WITH LEADS. USE PART NO 15862656. RESISTOR IS CORRECT WITH 2 MOUNTING HOLES. IF OE IS CAST 52408586. OR. 52418121, AND HAS 4 MOUNTING HOLES. USE PART NO 22807123 $85.24
1yesfan
those are not cheap. ha ha Rockauto has them 1/3 less, if I knew which one was which for the truck
1yesfan
Yea I was just going to pull it and look. I should have done this when I replaced the darn cabin filter though I was fine with just #1 setting not working at that time, now that 2 is dead I have to put it on 3 and with ac on, gets a little cold.
OR VietVet
Multnomah Falls
Military
Willamette Valley
You can also punch in part numbers at Amazon and save on shipping but make sure it is an AC Delco part and not aftermarket. @915_Tahoe is quoting you the price he sells them for at his job.
ZeroHour
