Losing oil
vdub77093
I started losing oil after I changed it. Had a small leak but used synthetic oil this time and now I have to add a quart every 2 days. Not leaking from filter or drain plug. Heard something about cooler lines but really not sure. Any suggestions?
Sasquatch
Orange County N.Y.
Climb under the truck and look for your leak. If there`s oil all over and you can`t pinpoint the leak clean it up as best you can and let the truck idle and climb back under and watch where it comes from and let us know where it`s coming from.
95escahoe
Oil cooler lines, rear main seal, oil pan gasket x2 on the method listed above
Multnomah Falls
Could always get real fancy and do an oil dye and light inspection. It puts the cool in leak detection.
V
vdub77093
Thanks for all the replies. I fixed the leak. It was the oil pressure switch.
06Escalade
Now your baby can use the good stuff. With no worry about leaks.
Bigbertha78
If you don't mind me asking, which oil pressure switch brand did you go with and why? I've heard the acDelco was best but didn't know how much it mattered!
Chubbs
I got whatever Oriellys carried with a lifetime warranty; it works just fine. BDE or something like that.
Tkrysl
So the oil pressure switch was leaking oil? I knew these went out because several of the suburbans I looked at were inoperable, but I didn't know they leaked oil.
Sent from my SAMSUNG-SM-G930A using Tapatalk
Fingers
