The guitar zombie
- Joined
- Jun 1, 2017
- Posts
- 20
- Reaction score
- 9
My 2006 Yukon Denali sat for 3 years. Everything worked back then except for an intermittent gas guage. The Car runs. The Code scanner will not connect to the computer (I had a earlier post on just the scanner, but now realize there’s a larger problem than just not being able to read the code scanner).
The radio volume is silent despite being on.
The steering wheel computer inputs do not work (display below speedometer) except the top right steering wheel button will only toggle between Engish French and Spanish (but won't let me select one).
The guages work (battery, = oil pressure) but the gas guage does not, except it reads empty with the fuel light on as Imput gas in it and did not move. In the past, when everything else worked, the gas guage was intermittent.
The check engine light is on.
I don’t think onstar works on the mirror.
The overhead light works, air conditioning and heat work (fans OK). Windows locks, everything else seems OK. The code scanner does do a successful battery check, but as stated will not connect for codes.
The above problems seem consistent and do not vary.
I am hoping there is a psychic out there that can help me or someone who can do a remote vulcan mind meld, but am willing to hear any other thoughts as spending too much on this 127K mi car is not worth it.
