Low pressure ac switch location
UmmScott
Omaha
I’m happy for any advice: this is what has been done so far.
Evap and Dryer freezing up, but only on lowest 3 fan settings. I checked refrig level and it’s perfect. I had the system evac’ed, power flushed, and the oriface tube replaced. I also had the computer re-flashed to an upgraded AC program.
Did not fix the problem.
I would physically turn the compressor off by turning the AC off in the cabin. Let it thaw out, then turn it back on. After a few reps of this, the compressor refused to turn back on.
After parking with the motor off for about 20 min’s the compressor will start but back to square one with the freezing on lowest fan speeds.
From my research (not claiming to be an expert by any stretch), I think it either has to be the AC pressure switch or the evaporator temp sensor.
im hoping it’s the pressure switch under the hood instead of the evap temp switch behind the dash.
Any advice will be appreciated. I’m certain I’m the least knowledgeable of anyone on this thread.
thanks in advance.
someone did all that and didnt check the pressure switch...
Wow [emoji16][emoji16]
Sent from my SM-G975U using Tapatalk
TheBigDirty
When I was first looking at this, I was pretty sure that I followed that line, with the pressure sensor in it, from the compressor to the condenser, which lead me to believe that it is a high pressure cutout. This is where Im so confused on this one.... the picture posted of the service manual labels the "low pressure" switch to be right by the filter/drier which on the truck is in the discharge line.
Every where I look try to look at different schematics, they all show that pressure switch in the line with filter drier and this line is labeled as the "discharge line".
The following is from AC Delco parts website.
A/C Refrigerant Discharge Hose
Part Number: 15-34531
Product Notes:
All; Compressor To Condenser; AC FRT AUTO/AUX CONT(CJ2), AC FRT MAN/AUX CONTROL(CJ3), REAR AUXILLIARY AC(C69); VIN: 0, Eng Code: LMG*; All; Compressor To Condenser; AC FRT AUTO/AUX CONT(CJ2), AC FRT MAN/AUX CONTROL(CJ3); Exc REAR AUXILLIARY AC(C69); VIN: 0, Eng Code: LMG*
Per Vehicle: 1; Years: 2007-2014
This kinda confirms my prior belief that there is no low pressure cutout, only a high pressure cutout.
Keep in mind my truck does have rear aux heat/ac. Maybe this differs for trucks w/o rear aux heat/ac?
What service manual was the picture taken from?
PG01
Up here to the right
Product Notes:
My 13 lt with rear Heat/air has it right there, like the pic and fwiw it is called a low pressure switch/pressure sensor
TheBigDirty
Where have you seen it called a low pressure switch? Other than that service manual picture. That line runs from the compressor to the condenser. When the compressor is running, that line is hot. That tells me it is in fact a high pressure switch. If it were a low pressure switch, it would either be on the suction accumulator or in line between the suction accumulator and compressor and would feel cold and sweaty while the compressor is running.
PPV12HOE
NC
On mine the low pressure switch is in the line... the high pressure switch is located in the rear of the compressor...
UmmScott
Omaha
2013 body styles ONLY have a high pressure cutout.
There is NO low pressure safety. Its controlled thru an evap temp sensor
kbuskill
NE. FL.
I thought I remembered @Rocket Man confirming that the SUVs didn't have the evaporator temperature sensor and that only applied to the Silverados.... maybe I'm confused.
On my '08 Burb the low pressure switch is on the accumulator as I recall.
PG01
I dunno, I lookeded at the pretty pic then poppeded my hood and didn’t see another switch In mine....my baddddd
wjburken
Eastern Iowa
The picture does says low pressure sensor and not low pressure switch.
My manual shows the low pressure switch on the accumulator but my 2013 doesn’t match the picture so I give up.
brichter
If I recall correctly, the low pressure switch is located on the high pressure hose, and it detects low refrigerant pressure and interrupts the compressor cycle when the refrigerant is lost. That's why they call it a low pressure switch, because it's function is to detect low pressure.
wendymoses
