Low pressure ac switch location
Cjherndon
Trying to find information on the location of the low pressure ac switch for the 2011 Chevy Tahoe. Suspect it needs to be replaced but can’t locate it.
13BurbanKid
Port Charlotte, FL
You should have what they call an "AC Pressure Transducer" mounted on your receiver/drier.
13BurbanKid
Port Charlotte, FL
That strikes me as very very odd. Every single listing in my parts catalog has a switch of some sort on the drier. Can you post a picture of your drier?
TheBigDirty
I'm currently trying to figure out an AC issue in my 13 Tahoe LT... it acts as though a pressure switch is cutting off the compressor. Ive checked the charge. Its good. I cant find a low pressure switch. Usually it located on the suction accumulator, but there is not one. The only pressure switch I see, appears to be to be a high pressure cut out. Well I took a big gamble with no real diagnosis time and replaced it. The parts cannon has missed on the first shot. Not to hijack, but Im along for this ride to find a low pressure cut out as well.
wjburken
Eastern Iowa
Thank you for posting that. Does the refrigerant need to be evacuated to change the switch?
Not that I am aware of. There is a valve in the port that the sensor opens as you install it. You may get a little puff of refrigerant as you are removing the sensor.
nuggettss1
