Low pressure all of a sudden
mijohnst
I might have just done something dumb. I added Seafaom to my Tahoe's oil last night. I'd done it to my other Yukon and had no issue. It was about 1/2 a quart low and input a full can of Seafoam in which likely overfilled it. It drive fine to work but I noticed at lunch that the oil pressure is now at zero. When I'm driving though it will go up to nearly 10.
It seems to idle fine but a few times it felt like the engine was about to stall when accelerating from a stop, but didn't. My plan is to get it drained when I get home and put in new oil and filter. I just recently put in a new oil pressure sensor So I don't think that's it. I praying I didn't just wear out my oil pump though. Engine temperature stayed normal the entire time.
Any thoughts?
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
You may have cleaned enough dirt/grit with the Seafoam that you have clogged the new sensor. That is a WAG.
Best case, the Seafoam freed up some chunks of sludge that clogged the sensor and you actually have more pressure than that. Worst case, it freed up enough sludge to clog the filter or pickup tube.
Like they said, change your oil before you drive it next cuz if there is a problem, that may be the last drive. The inconvenience of changing the oil at work is far less than the inconvenience of replacing the engine.
After the oil change, I'd suggest cutting open the filter to see if it's clogged to try to have some sort of an answer. You'd also get an idea of how nasty it may be inside your engine. If this prompts you to do so, you could pop off a valve cover to get a pretty clear idea and how you should proceed.
Going forward, you want to gradually dissolve sludge/buildup to remove it instead of trying to chemically break it loose in chunks.
Like they said, change your oil before you drive it next cu if there is a problem, that may be the last drive. The inconvenience of changing the oil at work is far less that the inconvenience of replacing the engine.
What's a good way to gradually break up the sludge?
mijohnst
mijohnst
I really appreciate all the advice. As suggested I got a ride home after work and drove back with all my oil change equipment. Drain all the oil in the place the filter. I let it run for about 5 minutes and oil pressure came up to about 20 psi. That's about half what it normally is. Drive it home (2 miles) and it seemed to drive okay despite having low pressure, and a few times that it seemed to choke up for an instant and then pick back up. I let it sit for last 30 minutes and just went out to see, and now I'm back at it 10psi it won't idle without me pushing a little gas. Uggg...
So my question is this, would the oil pressure sensor cause the engine problems? When I first got this Tahoe it was pegged at 80 psi. Last month I changed it and it went went back to normal. I didn't buy an oem, so I wonder if it went bad already and it reading low oil pressure is causing the engine to not run correctly.
I also ran codes on it, and I'm seeing P0101 and P0640 which say the mass airflow sensor needs to be replaced. I've never seen that error before. Would that sensor just go out all of a sudden then engine to sputter? I don't know if the sensors actually affect the engine as a safeguard, or they just come up as warnings.
OR VietVet
GMT800 SUV/Trucks
Military
Willamette Valley
I would change the sensor again with an AC Delco one. I am not sure but when you are at idle and in gear the pressure is lower and for some strange reason the system is trying to protect the engine buy trying to shut the engine down. Like a LIMP IN MODE. I could be way off base. If I was trying to break up sludge I would do a 1/2 quart of trans fluid and change the oil and filter again after running that for about 15 minutes at close to idle. That doesn't mean I am right, it just means I am trying to come up with a way to bring pressure back to what you are comfortable with.
matty40
