Lower shift cable
dirtydenali07
Bushing in end of shift cable where it attaches to arm disintegrated. Bought Dorman Help bushing, ruined 2 trying to get it in, as well as snapped the plastic neck near the mount. Have zip ties holding neck together so I can shift to park, and wire holding cable to arm. I need to order a new cable, but rock auto lists 2 different lengths for the lower cable: around 59.25” and the other is a little over 63.77” Advanced auto only lists the 63.77” cable. I just pulled cable out from under Yukon so I could measure it, and it appears to be the shorter one. But, Summit Racing does not have 2007 Yukon Denali XL listed for the shorter cable. I’m confused. Should I just order the shorter one? ‍Also, would it hurt to order the longer one, as it’s only 4” difference?
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
GM#520787606 CABLE, A/TRNS RANGE SEL LVR (AT TRNS) (LWR CBL) (WHEN REPL MUST REPLACE UPR CBL 25995564) (MT1,M30) $50.63
NOTE: MUST REPLACE UPPER CABLE WHEN REPLACING LOWER CABLE
GM#25995564 CABLE, A/TRNS RANGE SEL LVR (UPPER CABLE) (M30,M70) $37.56
dirtydenali07
dirtydenali07
What is the length of the lower cable?
dirtydenali07
dirtydenali07
Also, I just searched that part number at gmpartsdirect.com and it says 0 results.
dirtydenali07
dirtydenali07
These don't have the dimensions of the length.
Thank you for the help. I was able to order the correct lower cable from RockAuto. Now my new problem is the little clip that connects the upper to the lower cable broke when I removed it, and I can’t find one at my local Napa or advance auto. I called dealership and they lost it as coming with upper cable, and they couldn’t give me a separate part number for just the clip. Would you happen to know where I could get the clip? I have the vehicle up on jack stands, and my wife needs to go to work in an hour.
915_Tahoe
HELL PASO, TX
That clip is not serviced separate, i noted there that you must replace the upper cable due to a design change and the clip only comes with the cable.
Cody13Wayne
