Lowered 21+ T1xx: Post Em Up
jordan11
I forget the measurements. But only one small ring on the front shock and one larger (iirc) one on the rear.
Phillysays
Pictures of BellTech coilovers installed. Lowered approx 3 inches up front and 4.0 inches in the rear. Rides firm, but handles like it’s on rails. Part #15009 front and part #15013 for the rear. Super easy install overall, and nice to not have to mess with OEM strut/springs. Just rip and replace with the coilovers. E7A5E81E-4ABC-4F94-8268-BF65F78A0906.jpeg
CMoore711
The 21+ models can benefit from some lower offset wheels.
Even those 24” x 10” Vossen’s with a +25 offset are pretty tucked.
The wheel wells are definitely larger in diameter and wider on the 21+.
arcticcat522
First post....about 3.5 front, 4 in the read. 2" drop spindles and lowering struts in the fromt, lowering struts in the rear. ...also to anyone lowering....the front passenger side, remove the bolt on the rear battery tray. If you don't your tire will get tore up from it hitting. Could use some spacers, but I still like it. Also, just took the grinder to the little stop on the lower a arm to get some better turning radius. Helped alot!!
Rgray76
