Lowered escalade with auto ride
Modded
That Guy
Yeah I have extra sensor link sitting around too, pretty sure they can work as the 00-2010 Tahoes all have the same rear suspension.
vjr021
Clearwater, FL
Is there a write up on adjusting the bars??? I'd like to do mine as well...
Also is there a write up on removing the autoride completely?
Narco
Atlanta
i thought you had to get a whole new set of rear shocks to drop the autoride
chistoso
chistoso
Arizona
I think I got it to work.. I simply took off the links, popped off one of the ends and trimmed off about an inch and put it back together. It sits just perfect and the auto ride kicks in only if I get a few bodies in it..
Sam Hamm
when u buy a kit it tells you to bend then at like a 70 degree angle but when i did they broke so i just measured the length they were suppose to be at popped the end off cut it at that length and glued it back on. if i can find the paper i will tell you the correct length they are suppose to be.
Sam Hamm
love ur truck bro. ive been wanting to ditch the 6s for 4s for a while now.
