What the consensus on running LT tires vs P tires on our trucks? I occasionally tow but its just a DD most times.
Also, will running larger diameter tires cause premature wear on the transmission? I'd like this truck to last as long as possible
You can tow with P-Metrics just as well as LTs on our light duty trucks. The P-Metrics use less air to meet their weight ratings. The LT Load Range D and E are of course much more heavily constructed and heavier too.
Our trucks were designed to run up to a 32" tall tire in either a P-Metric or a Load Range C LT. So even an E tire in stock sizes weighs 15-20+ pounds more than the OE tires. Can the hubs and drivetrain handle it? Yes but it will reduce service life, especially a wider tire.
When I bought my truck it had BFGs in LR E. Truck got moving like it had a high stall torque converter and didn't coast at all when you let off the gas. I swapped them out for LR C tires and she coasts now and no more lag off the line. I was hoping they would be stronger, more road hazard resistant but after three years, three tires have been patched! Would not have happened with Es! Some of those nails would have tore up a P-Metric though.
I am giving serious thought to running a taller tire next time around, 275-65-20s will not rub and is 34" tall. I'll regear to 3.73s to keep rpms near the same. Tires in that size though are all LR E. We shall see.
