Lug Wrench recommendations?
Scottydoggs
NJ
MassHoe04
Western MA
I keep a pretty solid cross-style (+) lug wrench in the back of mine.
It is good for two-hand or kicking to break lugs loose.
If you have to do lugs by hand, the cross wrench is easy to spin to speed up the removal or installation process.
I recently got a set of 2013 Tahoe wheels for my 04.
FSM says 140 ft. lbs.
I set my digital torque wrench to 139.
Normally not an issue with zipping them off with my DeWalt impact.
On one of these new wheels, i had a hard time with the impact on 2 of the 6.
They just seemed to not want to budge for some reason!
Battery was on one bar on the charge indicator LED. Maybe it was tiring out... I thought it was all or nothing until it got fully drained. Maybe not...
Breaker bar did it no problem.
drdave81
Waterford, MI
Ditch the 4 way, its not 1972 and you only have one size lug nut. Get a 22mm socket and a breaker bar, good to go. I torque my lug nuts as well, but in a roadside tire change, I'd just make sure they're tight with the breaker bar.
89Suburban
Bull in the china shop
SE PA
I used to drag around a cross bar tire iron, stuck it in the garage and tossed this one in the back:
Have still never used either one on this truck.
Impact gun or ratchet to remove them at home and they go back on by hand and tightened with a long Tekton torque wrench.
I have the same one in the Hoe. I haven't needed to use it yet tho.
X3 this thing kicks butt. It's been transferred to my 3rd vehicle now. Great when I am pulling the boat and need it too for the different size nuts. Takes very little space. Nice storage bag. Once you break the nuts loose you can roll it like a choo choo rod to spine them off lol. Originally bought mine from pep boys.
That's a good price.
BG1988
So after having a tire issue on the road for the first time since owning my Tahoe I have decided that i need to carry a better lug wrench with me in the truck. I was thinking just a craftsman breaker bar and extension. Does anyone have any recommendations on a lug wrench to carry with me? I like standard four way wrenches but they just aren’t good to have sliding around in the back.
go to an antique shop and get a real one made from steel
13yukondenalipsl
