Thomas Hennigan
I've got a 2002 Yukon Denali with 274k on the clock. It's been leaking oil for 60k miles but I've kept it in check with StopLeak products. However, now when I run the highway at 75+ mph I lose significant amounts of oil, like a couple quarts on 60-90 roundtrip. From the threads on this forum it could be:
Valley pan gasket
Valve cover gasket
Rear Main seal
Oil pressure sending unit
Oil pressure block off plate
Oil pan gasket
Oil pressure sensor
It's beyond StopLeak, I gotta do something. The dealer didn't want to touch it. My longtime guy said it's a rear main seal, but he's old and can't handle it. The third mech wants to start up top w valve cover gaskets and oil pressure switch.
Is a leak of this sicope most likely a rear main problem?
Valley pan gasket
Valve cover gasket
Rear Main seal
Oil pan gasket
Oil pressure sensor
