massive oil leak in wheel well??
2002tahoegarbage
I have a 2002 Tahoe with 219k miles, i know damn well it has a rear main seal leak but i don't remember having to add 2 quarts every day, and my wheel wells are covered in oil, the underneath is covered in oil but there's no oil on my suspension parts or anything so have no clue why there's oil absolutely everywhere in my wheel wells
S33k3r
Dallas, Texas
Transfer Case leaking? Also, have you looked from the top down?
ID10T error. The transfer case would NOT make your engine oil disappear. Sorry about that.
That said, the only places you could be leaking oil is, as said above, the oil cooler lines, or engine seals. Base on your description, maybe you're leaking through a head gasket? Maybe check your oil for water infiltration?
rzabel
Redmond, Oregon
The way I read the original post, it may not be engine oil. I had a problem with the brake cylinder that sprayed brake fluid in my driver's side wheel well.
MassHoe04
Western MA
A bunch of photos might be helpful to see what is going on. Start snapping away and post... It would be a big help.
BoatsBros
