Mike's 2013 Tahoe Build
mjenk430
mjenk430
Unionville, VA
My new wheels/tires came with TPMS stems. Thought I could do the manual procedure to reset them but it didn't work. Did some searching online and found out GM stopped allowing the manual method in late 2011 models. Have to go to dealer or purchase tool. I don't want to go to the dealer every time I rotate my tires so I found these. Anybody have any experience with either tool?
http://www.tirerack.com/accessories/detail.jsp?ID=177
https://gmspecialservicetools.spx.com/ToolDetails.aspx?id=5677
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Turn the key to the on position but don't start it up. Press the lock and unlock buttons on the remote at the same time until the horn honks. Start letting air out of the drivers front tire until the horn honks again, then move to passengers front and do the same thing, then passengers rear then drivers rear. Make sure you let air out until the horn honks for each wheel. Turn key off and fill up the tires.
See if that works out
mjenk430
mjenk430
Unionville, VA
Already tried...twice. Went to owners manual, says you have to have tool. Went to Internet, GM stopped using this procedure starting with late 2011 models.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
see thats what was told to me also mine worked though on my truck.
mjenk430
mjenk430
Unionville, VA
Yours must have been manufactured before Jan 2011.
Here's what I found online.
"GM Product Engineering has determined that in some instances the manual re-learn
procedure can cause the TPM system to pick up stray sensor signals from nearby vehicles
which can result in Diagnostic Trouble Codes being stored and parts being unnecessarily
replaced. To address this concern GM Product Engineering will be disabling the TPM
manual re-learn capability from the vehicle software starting January 2011."
mjenk430
mjenk430
Unionville, VA
I did. Hopefully it will be here tomorrow.
White mirrors came in Tuesday. Handles are on their way. White plastidip came today, going to try it out on the front and rear Chevy emblems.
Trying to decide what to do with the chrome grill and surround.
clublub69
