grouch
- Joined
- Jan 23, 2019
- Posts
- 1,492
- Reaction score
- 3,637
Found the problem. I decided to swap out my spark plugs and the ones that came out were gas fouled from the TBI leak. I wasn't able to change 3 of them as the headers are too tight. The old gal ran better but still not right. I decided to double check the timing as I did find the header panel was from a different year and the timing specs were off. Slapped the light on it and the timing was all over the place. Out of the corner of my good eye, I saw something moving. The distributor was bouncing up and down. I reached over and pushed it down and the engine smoothed out.
The hold down clamp had a hair line crack under the bolt. It had broken and was allowing the distributor to move around and up and down. I had an old one in the garage and swapped it in. The engine smoothed out right away. I still need to retime it as well as other things I adjusted. However, while it still bogs down, it's not cutting out like it was. Maybe I've found the root cause of this.
