Misfiring issue
DallasTahoe
DallasTahoe
are your rpms dropping while your driving?
No not at all while driving, only while sitting at a light or in traffic, the idle just goes up and down, and only when it is warmed up real good
DallasTahoe
DallasTahoe
Any change by putting the old coil back in?
I changed out the coil and there was no change, but here's what I'm thinking... My misfires are at cyl 6 and 3, After looking at one of my old caps I see that these two cylinder spark pathways go right next to the main coil input, so maybe that's how my misfires are happening?
DallasTahoe
DallasTahoe
Yesterday I got a new AC delco cap and rotor and even replaced the distributor drive gear, since it was worn pretty bad. now I get about the same amount of misfires but across more cylinders, not just 6 & 3 I don't know what to do. I'm so tired of diagnosing and spending money... Help?
DallasTahoe
DallasTahoe
Sooooooo I believe I fixed it!!!
I pulled the passenger side valve cover and reset the valve lash on all 4 cylinders, put it back together and put my obd2 adapter on, started it and it started right up and I could feel a noticeable difference. Checked the scanner after I let it get up to temp and sure enough no more misfires on cyl 6, now I just need to readjust bank 1 and I should be good!!
Roscoe2352
