Missing "Stuff"
msark
As I have been going through, servicing and cleaning I found the following 3 items missing from by under hood fuse / relay box: A.I.R. Relay, Brake Lamp Relay and 30a Stop Hazard fuse. Everything on the car seems to work and it just passed smog here in Los Angeles... Thoughts??
SunlitComet
OBS Jedi-Do Good
unknown at this time.
need year of vehicle. unless it is a heavy truck chassis and most likely with a big block engine those will not be installed. Of course the Air system was used on Tahoes in '99, Can't remember for '98. The relay blocks were fitted in Tahoes, Suburbans, and trucks. But not every provision option is used. For example if you had a crew cab dually with a 454 all of those would have installed plus a few extras.
M
msark
I was cleaning and checking under the hood. I opened the cover on the fuse box to see if there were spares available in case one blew and to clean out the dust... The 3 items missing are on the drawing that's inside the cover but are not installed in the fuse box. I don't know if I need them or they were installed in other versions of the Tahoe and I never had them....
QUYHMK
