Can you bend the manifold heat shields out at all?Take the heat shields off of the manifolds, but be ready for breaking bolts when you do it. I don't remember much when we did, just that it was a royal pain.
I guess it's possible, didn't try to bend them to our will! The next time we do this, I'll make sure to jack the motor up a little higher and maybe even just remove the exhaust manifolds for better access to the mounts.Can you bend the manifold heat shields out at all?
How do you recommend jacking up the motor for this?I guess it's possible, didn't try to bend them to our will! The next time we do this, I'll make sure to jack the motor up a little higher and maybe even just remove the exhaust manifolds for better access to the mounts.
Piece of wood on a jack on the oil pan, jack it up slowHow do you recommend jacking up the motor for this?
That’s what I had thought. I saw a suggestion the other day of a jack under the exhaust pipe. That seemed a bit risky.Piece of wood on a jack on the oil pan, jack it up slow
Yeah I saw that too. All you’d be doing is jacking up the catylitic converter and the exhaust manifold. I’m with you not sure I’d trust thatThat’s what I had thought. I saw a suggestion the other day of a jack under the exhaust pipe. That seemed a bit risky.
