My 2011 Escalade Build Thread!!
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
well tomorrow going to take the djm hardware kit off and put zerk fittings into the endlinks in rear. Then just go over the spohn bar kit and grease them up. Oh yah going to install the belltech tb coils. The front of my truck came down perfect pretty much where I wanted it if i can get the rear down another 3/4 of a inch ill be set
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
im done with the suspension. Found the perfect combo rides so good right now and handles great. Im selling my 5305 coils now
---------- Post added at 12:53 PM ---------- Previous post was at 12:51 PM ----------
zerks installed on the djm rear hardware kit. find more info here on that http://www.tahoeyukonforum.com/forum/showthread.php?t=44731
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Just swapped to the new version belltech tb springs in back of my escalade and I can honestly say im done with my suspension set up for it. Rides great!!!! I've been thru pedders/mcgaughys/belltech/eibach pretty much on my truck and now i found the perfect combo and I'm finished finally.
My set up includes
Front belltech spindles
Front Norcal SS modded struts (helps ride due to autoride link movement changes valving)
Front/rear DJM swaybars
Rear Norcal SS modded DJM hardware kit
Rear Belltech tb coils (new version)
Rear Spohn Panhard bar
rear spohn lower control arms
Only thing I will be adding is helper bags for towing (autoride still lifts truck up perfectly)
Just wanted to put the info out there and I'm just glad I finally got the truck dialed in and finished!!
THE YETI
Director of Operations
South FL
Confused? You put the new version DJM springs in back, but you're post then says bell tech?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Some pics from today
wqshaider
