My 5 Alarm Hoe
C
Cattivo
The Concrete Jungle
OK correction: the Hoe is an 01. The esky is an 02?
Correct, Esky is an 02...Hoe is an 01
The mileage doesn't really matter to me as long as I stay on top of changing all the fluids. The only problem I'm having now is how to remove and swap both steering wheels
C
Cattivo
The Concrete Jungle
All NBS Escalade's have the 3pc cover the 02 is the only year it has the Caddy logo on it the other years just say Vortec 6000
I was unaware of that... I just need to find a place to swap out engines without going broke, just dropped lots of $$$ on new hardwood floors for the house
I hope you didn't do that Pergo crap, that fake hardwood flooring. That stuff is garbage Imo.
MadDogDelpho
Texcellent
Texas
An auto parts store should have a steering wheel puller for rent. To get the airbag off you need to have the battery disconnected for at least 10 minutes to be safe, then stick a screwdriver or something similar in the two holes in the back of the wheel and push from the inside of the wheel out. It should come off fairly easy. Then the yellow plug on the airbag needs to be removed, pull the little tab off, then the full plug. Then the red wires that run into the hole on the top left of the center needs to be turned clockwise on the little white plastic part and it should come out. Then you remove the big nut on the steering shaft then use the puller to get it off.
C
Cattivo
The Concrete Jungle
Thanks brother, I'll give that a try in the morning
C
Cattivo
The Concrete Jungle
I spent 9 hours completely gutting the Hoe, installing new black molded carpet and installing the rest of the Escalade interior
I also ran all new RCA/VIDEO/SPEAKER wire under the new carpet along with the new wiring for the front power seats...the power/heated front seat wiring was installed using a wire loom to keep the OEM look
I also have no idea what this hose is under the carpet on the drivers side thats been keeping my carpet/floor mat soaked since the day I bought it
tony97218
