My 98 stalls when going to reverse
arsonfnder
Please help only stalls when changing gears from d to r?? Then hard to turn over
SunlitComet
OBS Jedi-Do Good
unknown at this time.
so stalls in reverse then you put it in what position to start? and no issues at all if you put in park or neutral from drive and restart by choice?
Donnie Yukonie
Yates Caretaker
I had this issue a while back never figured out what was doing it but ended up replacing the spider injector for another issue and it cleared it up
Sent from my HTC6525LVW using Tapatalk
arsonfnder
arsonfnder
thank you much, so you feel the spider injector will correct this?
SunlitComet
OBS Jedi-Do Good
well if it stalls in a sputtering way then maybe fuel related but if not i might think the ignition switch or wires are getting bumped loose in the column or or some how the the torque converter clutch is getting activated. try disconnecting the brake pedal switch to see if it still does it. that would isolate the clutch as the cause. really got me thinking the problem is in the column tho.
Tmart1990
