My latest Adventure, update 7/11/21
bigdog9191999
bigdog9191999
sw michigan
so not too many updates, got some parts for the saturn, got some put on, and a few more to do (couple parts for the denali also) , got a new fob case for the old key, then got a second new key and had a non fob chipped key made. so now there is no fob to fall apart as a spare that will last.
bigdog9191999
bigdog9191999
sw michigan
got all but one of the stickers and residue off the back of the car also,
air filter wasnt too bad, but the cabin filter was more than due, but it was the wrong replacement.
does pretty good at hauling groceries too! not as roomy as the suv's but does fine! lol
still getting used to this part.
bigdog9191999
bigdog9191999
sw michigan
got some batteries , and came with a free tool, so i grabbed a buffer as apparently i laid my corded one wrong over the winter and the pad is quite, ummm not flat. but the extra batteries will help with the rest of the blue lineup i have on hand.
also found at a local store and found another astra. (these come to find out, are pretty not common. )
and i also found the best solution for the 8.1 milage, using some 1.8's!
bigdog9191999
bigdog9191999
sw michigan
and just for some cuteness,
some liiiiiiitttle deer.
and here are some of the baby, just chilling.
and just look at the size of this baby! this is a 7lb 6 month old baby!!
and someone was interested in the cereal
and a fogger, because these mosquitos are getting ridiculous. see how this works.
bigdog9191999
bigdog9191999
sw michigan
well not been a ton of new stuff going on, but figured i would share what there is.
got some new brakes on the astra, and although the old ones didnt look that bad, it make quite a bit of difference, the new pads bite much better and one of the rear slides was froze up so getting all that working correctly again helped the feel and the parking brake function.
decided to use the buffer also, i used it to put the wax on the car with ( put on with the buffer and by hand to buff back off) you can see the line from being done and not, it pulls the oxidization off. and a couple of the whole car also.
bigdog9191999
bigdog9191999
sw michigan
buffed the headlights on the car also and they turned out much better than they had been . ( did it before waxing the car above)
so while i had the stuff going i did the headlights on the denali also, they turned out good enough i am thinking about buying the adapter plates to put some mini H1's in there ( i have clear corners for it already just need to get them on. )
bigdog9191999
bigdog9191999
sw michigan
a couple pics of my buddies grand prix that just got painted. the color is called purple rain. possibility of getting the wheels off it for our black sedan as he will be upgrading.
this was the car before.
and our sedan i may try the wheels on .
bigdog9191999
bigdog9191999
sw michigan
and i half ton i am looking to get as a replacement for the tahoe, from a guy that has a wrecker that i drive for from time to time. is a 00 1500 with 4.10's. was picked up with a broken tcase ( littereally came out going down the highway) i should have all the parts to fix it off my avalanche that has been sitting.
and a 2500 my dad is wanting to grab from the same guy.
bigdog9191999
bigdog9191999
sw michigan
a little different look at the fleet ( piled out of the way to do some mowing)
and a couple more of the growing boy.
wmah523
