BigBlackTrain
The wrap is sticky, and it is applied to a clean surface. As long as your paint is in good shape and the clear coat is solid, the wrap will stick right to it. The clear coat allows the wrap to be removed at a later date without damaging anything. If you don't have a good clear coat, then the wrap will damage your paint and won't stick very well.
It doesn't scratch at all. It's kinda like those clear car bras that are applied. It protects the surface. The wrap is just like all the work trucks and logo'd cars you see in your town, mine just has no logos yet. I wanted the flat black for a while. And yes, it washes just like normal, I just can't use wax, because mines a Matte finish.
Just make sure that you hire a qualified person to install it for you. Also, the matte finish absorbs oils from your hands, so I clean mine with a 70% alcohol to remove the oils. I wash mine every weekend, or every other weekend, but if it's dirty here and there, i can wipe it off with a wet towel, a gas station squeegee, or anything else and it doesn't ever scratch or damage.
Hope that helps
Hope that helps
Since ur going on about the wrap and im a dummy...
How does it hold up? Scratches etc?
Are you able to wash it just like any other veh?
