My wall
puckhead
CO
That squirrel is freakin sweet! good job on the box so far! you gonna wrap it up in something?
oh, i see you are gonna fiberglass it, nevermind lol
drowndindreams
Unknown
question, how are you planning on accessing the subs in the future? are you sealing it completely? also you if you plan on staying ported theres something that you can do with that. if at sometime you feel like switching from spl to sq you can plug the ports with pieces of wood. i did that to mine. i like it a lot.
2drhoeon4s
there will be an access panel in the back to remove the subs if need be. Also, I am glassing the inside of the box for reinforcement. Not the outside. Once it is in the truck i will be building trim panels to give it the apearance of a wall. then I will carpet it with a raised superman emblem in the front. It should look sick.
2drhoeon4s
got some updates....
I finished the box and put it in the truck. That took some work. I had to router the edges to get it to fit. I mounted my mids and high amps on the side. Next i have to run my wires, install subs, get my amp, install batteries. and build a flush panel to make it a wall.
What its going in....
puckhead
CO
I take it you havea trailer to haul your supplies in and dont need the storage? Lookin real good! Like the rims too!
2drhoeon4s
yeah I pull a trailer for my business. I want to paint it white but I havent had time...
puckhead
CO
Nice lookin set up! would really set it off painted with some bigger wheels and your logo on there! Keep up the good work!
OklahomaSideShow
