Mysterious Rub
maddawg
Still searching for the rubbing on my wheel/tire setup. It happens when i make a sharp fast turn and approaching a hill/dip in the road. If i turn quick left 90 degrees it sounds like it rubs right side rear but i can't find rubbed parts or figure out how to just fix it.
Do i go CCM 2.5" front /1" rear or .5" spacers or both.
Donnie Yukonie
Yates Caretaker
stupid question but are the shocks close to bottoming out?
maddawg
maddawg
I wouldn't think so i'm running 22's 305/40/22? it's just me in the truck it seems like i have soft suspension. I've been thinking of getting the z71 springs
nrcpharmd
Florida
If you're interested in the z71 springs, I have all four from my rig. PM me if you're interested.
maddawg
maddawg
I gotta find out the bennifit of putting them on and the cost
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
its the fender liner its rubbing. Inside the wheel well look in the upper right hand corner of the wheel. since your running a wider tire and when the body rolls when turning it contacts that space. I had that problem when i lowered and was running with 285s. You can keep driving it and it will wear in or you can take a heat gun, get that area nice and warm, then push on the plastic and hold it there for a minute until it cools. It will make extra space for the tire.
InTruckDesign
SW CT,
If it ends up not being the fenderliner then check the swaybar, I bet there is a rub mark on it.
Ohbaby94
