MZS 1.5” level kit on ‘22 tahoe high country
sanman28
I didnt actually take the shocks out so not completely positive, but there is a shit ton of wiring on top of the strut…weather or not any of it goes to the actual shock i do not know.
You might be able to fit either of those tires with no level/lift at all. The 305/45/22’s fit just fine before the level.
Perhaps. But gaining altitude is a must.
Begno
I just spoke to Rough Country regarding a Leveling Kit for 2022 Denali XL with MRC, they told me their Part# 1311 (for 1500 pickup) will work perfectly fine. Anyone have experience with this?
sanman28
tramirmhc
Could the lower mount bolt be flipped ?
Might be slightly tougher to install, but would have more clearance.
That’s what I did in my 2021 Silverado, slid the bolt in from the top. Had to remove spindle from upper ball joint and tire rod to allow enough movement to move CV axle out of the way. Planning to do the same with my 22 Tahoe premier.
tramirmhc
It’s the Kit I just ordered should be here tomorrow. Will keep you posted!
14HoeSSV
