N00b dashlight question...Dont hate me..
stereodesigner
So basically I tired the search bar. Maybe I'm just challenged and I'm not trying to re-post something old.
That being said, the dash lights I plan on getting from "Superbrightleds.com". I know you need 6 of the 194 bulbs (Search feature helped my figure that out) But which style do you use? There's like 6 different style of 194 bulb. Ive heard someplaces that certain ones you can dim, some you cant. Does anyone have this information?
the less led there are the dimmer they will be
I ordered the cheapest led and mine dim...others are saying there's don't dim though Idk why who knows
With the single leds I have in the dash you cannot dim, and I am almost positive it will be the same with the other bulbs.
sent from tapatalk2 using rabbit ears and aluminum foil.
I got the cheapest ones for the cluster from superbright and mine dim
Sent from my DROID X2 using Tapatalk 2
kaoticlife
Port St Lucie, Florida
Just read one of the above posts and they said they could dim with leds? Are the leds used in the instrument panel and wow mine don't dim at all, weird. I ordered the single leds from superbrightleds.com and the multi led ones from eBay maybe I should try the multi led ones and see if they dim..cool!:cool:
KPOD
Michigan
Exterior
Low Beam: 9006 - 2
High Bean: 9005 - 2
Fog Lights: H3 - 2
Parking Lights/Turn Signals: 1157 - 4
Corner Lights: 194 - 2
Third Brake Light: Assembly
Tail Light: 3157 SRCK - 2
Stop Light : 3157 - 2
Back up Light: 3157 - 2
License Plate: 194 - 2
Interior
Gauges: 194 - 6
Indicators(instrument panel): T1.5s - 16 total, but will vary depending on how many indicators you have operational.
HVAC Controls: T1.5 - 4
4x4 Floor Shifter: 194 - 2
Ash Tray: 194 - 1
Glove Box: 194 - 1
Headlight Switch: NEO4 - 1
Door Lights: 194 - 4
Floor Courtesy Lights: 194 - 2
Driver Switches: NEO 4 & NEO 3 - 1 Each
Front Passenger Switches: NEO 4 - 1
Rear Passenger Switches: NEO 3 - 2
Dome Lights: 211 - 2
Map Lights: 194 - 6
kaoticlife, if I want to replace my HVAC bulbs with some original ones, not LEDs, do you know what the bulb size would be? Appears T1.5 is a LED only size.
kaoticlife
:thumbup:That's one of the original bulbs out of my hvac unit, don't know if you can see the number on it but it reads tsd74
The one below:thumbdown: is the base and it reads "Toshiba" "v2"
SPLmonster13
SPLmonster13
Texas
Thanks dudes. Ill order em and see what I cant figure out. On the topic of lights, anyone use LED backup lights? Any better/more output? I have one out, might as well replace em both.
kaoticlife
That's my next thing on gonna do. I have led high beams but they aren't real bright. But I don't use high beams due to having hid regular lights.
slipping
Rosamond, CA
Same here. Just put the led reverse lights, brake lights and switch back turns in my ebay cart to order tomorrow. Can't wait to see how it turns out.
_Dylan_
STAY FROSTY
Some day I'm either going to put some 55w H3 bulbs from some old foglights or some HIDs in my reverse lights. :)
HAIGDEDNEDNA912
