Mordechai
- Joined
- Aug 28, 2021
- Posts
- 60
- Reaction score
- 28
Yes its in the stock location on the other side.You mean the other end of the panhard is hooked into the stock mount on the frame? I'm picturing the panhard being at a considerable angle.
As for the end links, you want the two rearward pointing legs of the sway bar to be parallel with the ground. So, however long the links need to be to achieve this is what they should be. However, if you have some links that are beefier, that one inch isn't gonna make any perceivable difference and you'd get more out of reducing the flex than anything.
The adjustable panhard just bolts in. With the stock one removed, the body should self-center over the axle (vehicle resting on the ground at ride height). Adjust the length of the bar so that you can insert the bolts and install it. Simple as that.
We can't guarantee any of these will fix your problem. We're just listing off the things we see that can contribute to instability. Address these things and you should at least see some decent improvement.
So I replaced the end links with the ones that were a little shorter, I don't think its much beefier but its straight instead of being curved for some reason and seem to fit a lot tighter, I'll include a pic of them side by side. Took a little drive and the ride is MUCH improved especially in the corners. Im still getting snapped right and left a bit but hopefully the new panhard bar will help some with that.
