NBS console swap with Floor mounted 4x4
chaingun427
chaingun427
OBS Mad Scientist
Mooreland, OK
uploadfromtaptalk1393596884487.jpg thinking.im going to need to add a spacer under the center of that panel to lift the rear up a bit so it matches the lines a bit better, I cut a bit too much out from underneath trying to make it flat
Sent from my SAMSUNG-SGH-I537 using Tapatalk
chaingun427
chaingun427
OBS Mad Scientist
Mooreland, OK
Spacer added, also added some door edge trim to the back of.the cut edge and im working on the new power ports as well
Sent from the 7th frozen circle of hell using Tapatalk
chaingun427
chaingun427
OBS Mad Scientist
Mooreland, OK
I could use a bit of a hand if anyone has a recommendation about a kind of non slip foam for the top of this unit, either self adhesive or something that can be glued down cause this stuff I'm using now will not take any kind of glue from hot glue to epoxy I have tried everything in my cabinets
TigerEyz3
Slow and Steady
TN
Not sure if it would work any better, but have you considered "Liquid Nails"? They make some for plastics/non-porous material.
chaingun427
chaingun427
OBS Mad Scientist
Mooreland, OK
I think it's the he'll material this pad is made from but I'll look into it
chaingun427
chaingun427
OBS Mad Scientist
Mooreland, OK
ended up using the bottom of a new floor mat, like a bathroom mat, removed the fabric and cut it to shape. I'll post a pic or two later. to cover the missing panel on the side i decided that i'm going to mount my cb radio there instead of trying to fabricate a panel.
the real wall i'm hitting at the moment is actually with paint. Duplicolor HVP110 is too red to match the existing trim, and i was wondering if anyone had any experience with SEM's burgundy paint that could compare the two?
chaingun427
chaingun427
OBS Mad Scientist
Mooreland, OK
Long time no update on this, i've finally had some time to get something done here. No paint yet but i've got the accessory fuse box installed and new sockets in the previously pictured power plugs. looking for a pocket to put where the cd player used to be in the console. also got the weather radio working finally
Colorado
