Chubbs
- Joined
- Jun 24, 2017
- Posts
- 634
- Reaction score
- 391
LHJ011 model# keyless entry remote. The Yukon that I bought back in April came with only 1 of the original remotes & single ignition key. I've been meaning to buy a 2nd setup for my spouse & emergencies & finally got it on eBay yesterday. My neighbor was knocking on my door Thurs night asking me for help breaking into his car as he locked the only key inside & that was the kick in the a$$ I needed to finally make my $12 play
There was a thread not too long ago & several people said that when the new fob is programmed, the original will no longer communicate. Something about both needing to be reprogrammed simultaneously. Does this hold true, or have any of you personally had any luck with the original fob remaining functional without tampering the factory programming in any way? Seems like the perfect way to get yourself in a jamb if you know what I mean.
Does WalMart & Home Depot cut car keys? If I was running a business I'd be asking for ID & registration but I don't know how that all works. Thinking the last time I needed to make a duplicate I cut the blank myself.
This is the purchase I made & instructions in 1 of the item photos that explains toward the end to repeat the programming steps for any remaining and/or original fob remotes.
https://www.ebay.com/itm/132403013148
