Need a new motor
blueflamed03
Oklahoma
Do you plan to buy a longblock, or assemble yourself a decent 355.
If you drive it moderate, just get a new longblock stock, add a small cam and exhaust and call it a day. :)
A
atis
New Bern, NC
I am looking for a long block, adding my votec intake and installing...trying to do it in a weekend (removal and install) I cant find a 355...google isnt my friend today!
blueflamed03
Oklahoma
a 355 is just a rebuilt 350, bored .030 over.
Example:
http://high-performance-engines.com...?Screen=PROD&Store_Code=ATK&Product_Code=HP32
specs:
Camshaft Type: HYD. Roller
Camshaft Lift: .495 IN X .502 EX
Camshaft Duration @.50: 220 IN X 224 EX
Cylinder Head Type: OE Cast Iron Vortec
Chamber Size: 64 cc
Valve Size: 1.94 IN X 1.50 EX
Intake Runner Volume: OE
Compression Ratio: 9.6:1
Rocker Arm Type: Stamped Steel
Rocker Arm Ratio: 1.5:1
Sheet Metal: Chrome V/C T/C Black O/P
Recommended Fuel: 92 Octane
Ignition Timing: 36 Degrees Total Advance
Max RPM: 5800
Warranty: 24/Unlimited
Dyno Proven: YES
A
atis
New Bern, NC
Understand the .030 over but the problem is I can find a long block to buy thats already punched.
I hear ya all on the 383. I just dont have $4800 at the moment.
blueflamed03
Oklahoma
see the one I posted, it's already .030 over..
stock bore is 4.0
Stage: 1
HP: 351
TORQUE: 400
Engine Type: Chevy Small Block V8
Displacement (cu.in): 350
Block: 4 Bolt main/Roller
Bore / Stoke: 4.030 X 3.480
Crankshaft: OE 1 Piece Seal
Rods: Powder metal
Pistons: Hypereutectic
Rings: Moly
A
atis
New Bern, NC
Blue Flame, that engine is not legal on pollution controled vehicles...we have yearly safety and smog inspections...what a pain, they even check your window tint.
How hard is it to stuff a 6.0L in her? That would require new motor mounts, computer and the such correct?
blueflamed03
Oklahoma
that was an example, you can find tons of rebuilt 355 Vortecs out there that are bolt on upper fuel injection and roll.
The 6.0 is a direct swap, just retune computer. All externals are the same.
---------- Post added at 07:57 PM ---------- Previous post was at 07:54 PM ----------
brand new 350, from Pace Performance.
$2099
http://paceperformance.com/index.asp?PageAction=VIEWPROD&ProdID=225980
retorq
Kingman AZ
The 6.0 is an LS based engine ... it's not a direct swap for a TBI 350 ... not even close.
Buying a 355 over a 350 isn't going to get you any more power ... if given a choice it's almost always better to go with a virgin block.
Stevemo70
