need advice on brakes 1996 Gmc yukon 6 bolt
JeffreyWoyc
Hi so im looking at replacing my brakes (mostly front) and i want to upgrade at the same time... I've been looking online and I haven't found much... I'm looking for new rotors, calipers and obviously pads... but I definitely want drilled/slotted rotors and I looking to keep it under 400 Canadian. So if anyone knows a good website I'd love to take a look at it
drakon543
If your replacing the calipers but staying under 400 your looking at stock oem calipers. As far as pads and rotors rockauto sells the pad and rotor combo for under 200. Power stop is a good brand. I do however suggest unless you spend alot of time racing a billboard on wheels or regular heavy towing slotted or dimpled and slotted rotors would be what your looking for. As much as it's feared drilled rotors do have a higher chance of cracking but its not really that common but it is possible. Unless i really feel the need for a little extra i usually just stock with slotted rotors.
Donnie Yukonie
Yates Caretaker
R1 D/S rotors here, Never had a squeak. I use ceramic pads
Roux
