Hello All,
New member and looking for advice from people familiar with Tahoe and Chevy's. Been wrenching on cars since I was a kid but I'm new to the Tahoe.
2004 Tahoe LT AWD 5.3 Vortec 190k
I'll start from the beginning. Driving to work one morning and heard loud engine noise, almost a clunking. At the same time the motor lost power. I had to stay on the gas to keep it running. I managed to get off the road and into a side neighborhood very close to my house and I decided to try to limp it home. Halfway there the problem vanished like it never even happened. I thought wth? Maybe a bad sensor or something? As the problem had gone away completely I figured I would have to keep driving it until the problem reproduced itself.
Flash forward a week and I do a scheduled oil change. A day or two later I notice I have lower oil pressure than normal at idle ~20 psi (according to indash gauge) but no engine noise or any other symptoms. Pressure is normal while driving. I thought maybe I got a bad filter and swapped it but the pressure did not go back to normal. A day or two later I was getting off the highway after a ~70mi drive and when I pull up to the light (by my house luckily) the oil pressure drops to almost zero and I get the low pressure warning in the info center. At the same time I start hearing valve noise.
I took the Tahoe to a shop so they could verify oil pressure with mechanical gauge. They confirmed it was way too low.
I then dropped the oil pan to check the pickup tube screen and see if there was anything wrong there. Inside the pan there was a small amount of what I suspected to be gasket material but nothing clogging the pickup tube. At this point I'm suspecting that the bearings and/or lifters are shot but my old man insisted that I replace the oil pump first.
So I just replaced the oil pump, cleaned the pan, new gaskets/o-rings etc. etc. Fired the engine up and I've still got almost no oil pressure and that same noise.
My questions to all you wonderful people are:
-Am I right in suspecting the bearings and/or lifters are shot?
-Any known issues associated with what I described?
-Should I pour some ATF or engine cleaner (seafoam etc) in there and see if it helps?
I'm kind of stuck between a rock and hard place with this truck. Not sure I want to invest in a rebuilt motor or rebuild this one. Not sure if I should just trade her in and take the hit on the value. Maybe some engine cleaner and take her right to the stealership?
Thank you much in advance,
Dan
Dan
