Need factory plug for panasonic dvd. Help...
farmerboy
I bought a 2005 Tahoe that had been wrecked and rebuilt. Obviously, while it was wrecked, someone stole the factory overhead tv/dvd player out of it and instead of unplugging the harness comeing out of the headliner, they cut it off. I have another player to put back in my tahoe, but I need that connector. Anyone have one that you have cut off or suggestions would be greatly appreciated.
F
farmerboy
---------- Post added at 08:36 PM ---------- Previous post was at 08:34 PM ----------
I called every junkyard around, and no one has a wreck that they will let me have the harness out of. Thought maybe someone on here might have cut one off to install a aftermarket dvd player.
theautoman21
There is a place called partstore.com that has pretty much everything you need to maybe build a deck dont be fooled with the alpine logo it has a variety of all kinds of stereo parts.
oak510_tahoe
Urban Assault
Maybe this can help if you can't find the connector ( this info was posted here sometime ago):
These are the pinouts for the GM Panasonic flip down DVD player found in most Escalades Denali's Tahoes and Suburbans
GM document ID# 1399571 and 1399582
On the 16 pin Connector
pin 1 YEL Battery Positive Voltage
pin 2 Tan Acc
pin 3 ORN Ident
pin 4 DK GRN Backlight Gound
pin 5 LT. BLU Video +
pin 6 DK BLU Ground
pin 7 BRN Audio Right
pin 8 PPL Audio Left
pin 9 WHT Backlight Batt+
pin 10 GRY Bus Data from Display
pin 11 RED Bus Data to Display
pin 12 BLK +5 Volts
pin 13 PINK Video
pin 14 BARE Video Shield
pin 15 BARE Audio Shield
pin 16 LT. GRN Audio Common
On the 12 pin Connector
pin 1 not used
pin 2 LTGRN/BLK VCM Class2 Serial Data (Data Link Connector)
pin 3 and 4 Not Used
pin 5 DK GRN/WHT Right Audio Signal
pin 6 BRN/WHT Left Audio Signal
pin 7 BLK/WHT Ground
pin 8 Not Used
pin 9 ORN Battery Voltage
pins 10 and 11 Not Used
pin 12 BLK/WHT Audio Common
The 8 pin Connector is Audio and Video inputs
mike15tahoe
