Need help ASAP
2010sublt1500
I have a 2010 suburban... I had a p0332 and a p0300 codeand p0307.... I Kno what these codes are I pulled the number 7 plug and coil an d they was fried.. so I did all new plugs and wires and coils.. pretty damn pricy but it was done. Ran great for a couple days and then I'm ok the highway today and my check engine light came on again... I used the scanner and p0300 comes up again except this time it's pending I don't know where to start ... I've run out of money andand patience .. please someone just point me in the right direction
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Do you have access to a scan tool that can log the misfires and look at the fuel trims? P0300 is a random misfire code and may be related to any number of issues including a vacuum leak.
It would help to go back over your work and make sure the wires are all on correctly.
Expand on what you mean by the #7 plug and coil being "fried". Also, what brand(s) of parts do you use and from where?
2010sublt1500
Number 7 had alot of build up on it and debris inside of it and I used nothing but ac Delco .. we all know these trucks don't like anything else
how many miles?
double check your work
get a scan tool and monitor the misfires
I have been down this road in the past..... once it was bad coil/s (even though new) another time it was the stupid maf in the end.
Ah. Good. I thought you meant the wiring into or out of the coil was literally fried, as from over current or electrical short.
You're already on the right track with this knowledge! On this note, some may post up info or suggestions that you're already aware of, especially in dealing with well-known problems. It's not presuming you have a lack of knowledge or skill, it's being thorough. My point in asking is that the market is flooded with counterfeit AC Delco parts, and they're sold on our beloved Amazon (Not bashing Amazon- they're just a marketplace). You had ignition-related problems which seemed to have been resolved with new plugs, but they soon returned as if the new part(s) were failing already. I just wanted to make sure you were aware of the fakes and, if there's any suspicion, get 'em out ASAP before they could cause mechanical damage. Start simple and make sure the wires are all fully snapped onto the plugs. The chances of having multiple wires loose, resulting in a random misfire code are slim. So it's more likely higher up the chain.
#7 having the excess buildup is a common symptom of the oil consumption problem these engines are known for. Do you keep tabs on your oil level between oil changes? Disabling AFM would be a wise start and adding a catch can is a must. I'd also advise that you determine if yours has the updated driver side valve cover. I think this was implemented in 2010, so yours may or may not have it. It's a worthwhile upgrade. Here's this if you haven't read up on it: https://static.nhtsa.gov/odi/tsbs/2012/SB-10062524-7690.pdf. Another member, @donjetman (This is twice in two days I've tagged you, Don- I hope you don't mind!) completely reversed his engine's oil consumption by following this TSB, and he substituted a cheaper and more readily available cleaner. If I could find his thread, I'd link you to it.
2010sublt1500
Thanks I'll check everything out that u sent me.. and your right there are alot on counterfeit acdelco parts out here .. I just hope none of them slipped into the dealer where I got mine from cause I spent alot of money on these parts we talking $130 per coil and $125 for the set of wires .. I was not happy trust me but I knew it was something I had to get done
a-reem
