Rebelution
The pinion seal on my rear diff has been leaking so I decided to replace it today. I marked the drive shaft and the pinion nut and everything before I took it apart. Tapped the new seal in all the way. Put everything back together exactly how it came apart. Anyway, I went to top off the fluid and realized the leak is worse than ever!! I took it back apart and can't figure out why it's leaking. Any suggestions?
