need some advice.....rear sagging
dre
Whats up gents????????? I have a ground force 2/3 drop on my tahoe.......I have a speaker box that weighs an ez 250++ and the rear is sagging.....I notice it more know that i put on my oem 17 for winter....I know taking out the box would help but its not an option.......would an airlift kit work if so which one?????? thanks
NASTY GM
Nor Cal
Change the springs to 2" drop. Belltech makes spacers you can put between the springs that raises the rear 1". I'm not sure if they will work on the GF springs though.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
the belltech spacers work on the ground force springs no problem. ID is the same. Hit me up if your interested i sell them
Zed 71
Pacific NW
I am not sure the Airlift would work because the bags might be too tall. Also, at the minimum required 5 psi it might raise the back up higher that what you would like. BTW I love mine :)!
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
get the belltech spacers and be done with it bro
MOBmentality
Has a $25,000 Punch
lower the front to match..
Problem solved
/thread
Austin12
