txhoescrapin
Our needy member :-)
That amp will not be able to handle the 1ohm load you are throwing at it. There should be a light showing you the amp is in protect mode, or possibly the amp melted down. hook the amp back up, and check the volt coming out of speaker terminal as stated before. Is the amp mounted in open air also, it could be getting hot.
