Need support. Just found out my radiator is leaking
iboughtatahoe23
iboughtatahoe23
naah, just look harder with a flashlight, take that splash guard off and look up.
and/or drive it and then park it over some cardboard, let it sit for a good while/overnight and then look up from the wet spot on the cardboard.
Good idea ha. But if I wanted to… is this safe to
ClayCollins
So I posted earlier about some gurgling noises under the dash and I figured it didn’t sound right because it was with the rev of the engine it would gargle. I got home and started inspecting the cooling system, and I found all my coolant all over my splash shield, and next to the radiator orange fluid everywhere in my coolant is nearly gone. I don’t know how this would happen. I thought I took really good care of my truck. I just got the radiator flushed and coolant a year ago not even
I just feel really defeated right now like I don’t know the most about cars like I just do what I can and now my coolant is leaking everywhere
Hose everything off and let it dry. Then run the engine for 5-10 minutes to get the thermostat open and shut it off and start looking for the leak. The sides of the radiator have seams that can start leaking. Just make sure it’s the radiator and not something else. It could be your water pump too. The plastic heater Y pipe near the firewall commonly fails, but it wouldn’t splash onto the fan shield. There are some good YouTube videos on replacing the radiator. My son and I did his no problem in a coupe of hours and we also replaced all the hoses.
iboughtatahoe23
iboughtatahoe23
Ya the water pump feels bone dry… I got a few other spots I want yall to look at. I got some dried fluid running down the inside of the, more specifically on both sides of the splash shield… looks new. Tonight i will pop that off and leave the cardboard under there. I also topped it off before I left my house around noon… I was maybe an inch and a half under the fill line when I topped it off. I let it sit for the day, came back. The level was the same. So I took it for a spirited drive around town… after I got back the coolant is still right where it needs to be…
Here’s the photos.
Photo one is the coolant tank before I filled it this morning. I had driven it last night and left it. Didn’t top it off.
This photo below is the fluid on the splash shield I think
Below is the left side of the water pump
Some more random pics
Yes, I’m aware of the transmission line leaking but it’s a very slow leak and seems to seal itself and doesn’t really correlate with the puddles below
Passenger side hose^ with trans line shown
iboughtatahoe23
iboughtatahoe23
Here’s the tank currently after a nice drive. Don’t lose much. If any…? I topped off on cold engine before leaving. image.jpg
Still seeping at this spot. Side tank ^
I’m not sure what this guy is driver side hose below the bigger hose looks like it might have a small leak as well
iboughtatahoe23
iboughtatahoe23
Here’s the tank currently after a nice drive. Don’t lose much. If any…? I topped off on cold engine before leaving. View attachment 450986
Matter of fact, in reference to the last photo on this comment, it looks like there was a TSB posted here for a power steering leak. This might be a little off-topic. https://static.nhtsa.gov/odi/tsbs/2013/SB-10043850-7806.pdf
BigD253
