New guy here needs some help..
C
Cougar1Car
Upstate NY
I don't see anything leaking.. Again all hardware in the drum is new. I can check on that. The abs isn't working the light is on gas been since I got it.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
If your light is on your abs could be actuating into lockup I would suggest you get that check immediately now that you mentioned it. A dealer has the proper tool to read the ABS module and pulling the code should only take a few minutes.
gpracer1
Phoenix
Now that problems kinda worked out I got another. I am having a problem with the rear passenger brake locking up if brake is pushed a hair harder than normal. Back brakes with all hardware were recently replaced brakes were adjusted than adjusted again and again. Still having the problem. Any ideas???
Should start a new thread, but maybe when the new brake shoes were installed, you put the both leading shoes one one side and both trailing on the other side???
I did that once when I was 16 on my 73 Nova SS and it took me a while to figure out.
I dont remember if the shoes are different on the Tahoes, but there is an excellent writeup here. http://www.handymanlyness.com/archives/auto/repair/brakes/GM/96_Yukon_4x4/rear/replace_brake_shoes_96_Yukon.html
C
Cougar1Car
Upstate NY
they have a leading and trailing size.
Does anyone have a photo of how it should look or what the pads look like and what goes where.. If I take it apart I wont know whats what anyway if its installed right or wrong...
gpracer1
Phoenix
You didnt read the link I provided, did you?
Go half way down.
SunlitComet
OBS Jedi-Do Good
On the drums the forward shoes has less lining length to it. The rear facing should have more.
---------- Post added at 04:49 PM ---------- Previous post was at 04:48 PM ----------
Fig. 1 Exploded View Of Drum Brake Assembly.
42239431
Dalewg
