New here. Michigan. 2009 Tahoe SSV
1BADI5
DMV
Welcome to the party
- Sadly, the 09 was the last year with the 4L60, the 6L80 was not til the 2010 model year (with a 5.3)
- Calipers are the same, BUT different rotors and pads
Chris Z
Chris Z
Which capacities are you looking for? Fluids?
with all the extra coolers mine has, it still doesn’t seem to change the basic numbers listed in the manual and other places.
yes, wondering if I needed more fluids for the additional oil cooler. I imagined the larger radiator would take more coolant though for sure. I usually refer to the manual, just want to be safe!
Chris Z
Chris Z
Welcome. Nice PPV. They robbed you with your rims tho. They took your PPV'z and gave you some nbs Z71 rims. Same size tho.
Right! Well I’ll be rocking these with some new rubber through the winter. The whole transaction was a little weird with them not disclosing it was a service vehicle.
Just hoping there aren’t any hidden surprises, and counting my blessings that it has the 6L80..
Chris Z
Chris Z
Lola, my daily hoe, was a K-9 unit. Talk about dog hair everywhere! My two hounds spent an hour sniffing every inch.
Welcome aboard.
Thanks Sparks! Is yours a PPV or were the Kanine units the SSV? I was curious about that as I imagine k-9 would do rapid response and have the PPV package. Cheers
Chris Z
Chris Z
Actually because this is 4x4 SSV not the 2wd PPV it does have the 6L80. I decoded the vin just to be sure. The ‘09 2WD PPV would have to be RPO K5L to have the beefier rear end and 6L80.
Someone correct me if I’m mistaken.
if the shifter has +/- buttons then you have a 6l80, if not then you don't, also the cluster will have PRNDM instead of PRND321
the oil cooler and trans cooler do not really add anything to the fluids levels maybe a pint
K5L is just enhanced cooling, 700w fans instead of 500w fans and about a 1/8" thicker radiator
G80 is GM's version of a beefier rear end which is ok for most people I have broken a couple, there are some other options @swathdiver knows the scooop
Chris Z
Chris Z
if the shifter has +/- buttons then you have a 6l80, if not then you don't, also the cluster will have PRDM instead of PRD321
My RPO trans order code is MYC, M30 which indicates the 6L80.
also has the +,- and PRNDM
Walkinblessin
