New-Nivomats... ( Old subject/new problem ) Do they exist??
So replaced all the suspension including new nivomats/springs and front shocks on my premium smooth ride Tahoe (2005) and wish I would have kept the springs. The moog replacement is stiffer(same spring height uninstalled). Now my truck doesn’t sit right. How can I find a set or correct springs??
Find someone who's doing the conversion to change from Nivomats to conventional and get the softer ones there.
mountie
mountie
Just a thought..... Since there are 3 or 4 (? ) versions of a ZW7 package, for the same type model, ( as per my research )..... Maybe check at your local dealer, for the parts used in those versions, and copy it, into the truck in question.
Use GM parts or an aftermarket with the same specs.
mwilson62000
You could look into ACDelco springs. Part 45H2165 is standard spring with Nivomats, 45H2164 is HD spring or z71. I installed 45H2165 and new Nivomats on my 03 Tahoe years ago and kept factory ride height.
What part #Moog springs did you install?
mattbta
Frisco, TX
This is one of the reasons I stayed with Nivomats - didn't want the rear to raise up any, which is a common result based on reading here about the conversion. Good luck.
mountie
mountie
I believe, the "raising up", is when you were towing or carried a heavy weight,.. then it returns back to the correct height, after removing the trailer weight.
I think what @mattbta is saying is that a CONVERSION deleting the Nivomats would raise the truck's ass end, due to new springs. All the time.
I suppose that might mean, the current set up may be too low?
No, I think it means that he's happy with the height that the Nivomats give it, and he doesn't want to jack it up higher. If it was too low, why would he not do the conversion? You're overthinking this.
TooManyCars
