New plugs, wires, cap and rotor now service engine soon light
kaoticlife
Port St Lucie, Florida
Well I've been trying to chase down the miss I have. Only misses at 65-70 MPH and if pulling the boat at 40-50 MPH if I feather the throttle it doesn't seem to happen so maybe dealing with pump or injector issues?
sent from tapatalk2 using rabbit ears and aluminum foil.
---------- Post added at 10:05 PM ---------- Previous post was at 09:07 PM ----------
Oh and no check engine light. Checked for codes and don't have any?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
fyi. there was a tsb on sticking valves in the guide but if many miles on it ignore. get a misfire history to narrow down the cylinders acting up. always available data from the pcm.
kaoticlife
OK Sun thanks. Need to get a detailed rundown I guess. Just have a small code reader have to look and see what it does.
TigerEyz3
Slow and Steady
TN
As previously stated, most likely the distributor got bumped (loose clamp/bolt) out of timing. I had a random multiple misfire situation about a year ago.... problem was due to a worn distributor gear. I replaced the whole distributor, cap, and rotor setup. Even though I dropped the new distributor in the right place (gear wise), I had to use a professional scan tool (that could read the cam retard) to get the timing straightened out and the CEL to go away for good.
a9lyphe
